eHoefler
Mar 19, 2016Explorer II
Remove the grill from the A/C and look up into it. Is the attic sealed off from the return??? You should not see any insulation or framing for the roof. If it is not sealed off completely, you can draw sewer gases through the attic from the sewers vents in the roof. The vent pipes are not sealed from the roof and just stick up just enough to be covered by the vent assembly.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
