Dutch_12078
Mar 19, 2016Explorer III
Old-Biscuit wrote:
A/C Unit can NOT pull any vapors thru water in 'P' traps....not going to happen
A/C Unit return air CAN pull odors from grey waste tank via the Air Admittance Valves under sinks on drain line downstream of 'P' trap.
OEM AAVs are just a thin flexible diaphragm held in-place by a 'tang' on diaphragm
Tang stretches...diaphragm doesn't seal off..stink from grey tank comes into RV.
Cheap ones available for $5 at Big Box Stores.....better ones/higher pricing also available
Just curious, but since RV A/C's are air recirculating devices where the inlet air volume exactly equals the outlet air volume, creating no negative or positive pressure, how does it draw air out of the AAV?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
