We are fulltimers, generally parked in moderate temperatures year round. We do not care for A/C. If the temp inside our rig gets above 90F, we MIGHT use it. That could occur but 2-3 times a year. He...
While you're at it, disconnect from shore power, start the generator and run the A/C while on the genny. This will exercise both and put a descent load on the generator to dry out the coils.
Also, be sure the condensate is dripping overboard. It's easy for bugs/mud to plug up the condenser drain tube. If not draining down the side of the RV somewhere, you'll need to get up there and clear the drain.
