StephenandRobbi's avatar
Jun 03, 2013
AC fan will not start
I have a Duo Therm AC model 57912. When the unit is turned on the fan will not start. It will run if you give it a turn by hand. I replaced the start capacitor and it did not help. I don't see any reason to suspect the run capacitor so I'm leaning towards replacing the motor. Any thoughts?
Thanks,
Steve
  • Ok, everyone who voted for the run capacitor, you are correct. I replaced it today and the AC seems to run fine. Thanks again for all the help.
    Steve
  • Just replace the run capacitor and it will be fine. FWIW, I have only found a motor with electrical problems once , and that was due to being hooked up incorrectly. Every other motor I have ever replaced has been due to bad bearings (and I have replaced a bunch).
  • prolandsurveyor wrote:
    Are u talking about the blower motor? The motor that blows air inside the camper? Or the condenser fan motor that blows air on the top of your camper?
    On a RV air conditioner, the same dual shaft motor operates both the evaporator and condenser fan.
  • Are u talking about the blower motor? The motor that blows air inside the camper? Or the condenser fan motor that blows air on the top of your camper?
  • Thanks for the info.
    There are only 2 capacitors in the system. A run and a start. Since it would run once started I assumed the run capacitor was good. It will run in either direction though. So I guess the best rout is to replace the run capacitor and then the motor?
    Steve
  • Chris Bryant wrote:
    The start capacitor has nothing to do with the fan. If it spins freely, replace the fan capacitor. (You can double check and try spinning it backwards- if it runs backwards, the fan capacitor is definitely bad)
    X2 on this.
  • Every last one I have ever torn down with those symptoms had a burned coil or two in the stator. Time to grit your teeth. Low voltage is a usual suspect.
  • The start capacitor has nothing to do with the fan. If it spins freely, replace the fan capacitor. (You can double check and try spinning it backwards- if it runs backwards, the fan capacitor is definitely bad)
  • Hi,
    If there is a setting for running the fan constantly use it.
    Some folks have tried to oil the (probably sealed) bearings.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 01, 2025
