time2roll
Aug 24, 2014Nomad
Does it have a wall thermostat? If so it should have a freeze sensor. Sensor is accessed from the inside and often falls away from the evaporator rendering it useless. Or was poorly placed during OEM install.
Also check the air plenum inside. Often the IN is not well separated from the OUT causing cold air to recirculate and over chill through the evaporator.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
