j-d
Aug 25, 2014Explorer II
Here's a Cleaning Process. It has to be done from OUTSIDE. On the roof, plastic removed along with a little sheet metal. Will give you a chance to check position of the Freeze Sensor. Also check to make sure your ducting isn't restricted.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
