dougrainer
Aug 26, 2014Nomad
kellertx5er wrote:
Isn't a properly functioning expansion valve supposed to prevent freezing, regardless of fan speed?
NO, is the simple answer. Expansion valves are what help produce the cold, NOT regulate it. There is no "expansion" Valve on a RV roof top AC unit. The use a Capillary tube system. Even on RV Dash AC systems with a Expansion valve, there is a mechanical cold tstat that shuts the compressor off if the evaporator starts to freeze up. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
