alogo4u's avatar
alogo4u
A/C-Heat control on dash
Greeting all!
Have a 2003 Hurricane 30Q motorhome. When I have the A/C or heat on, the air flows only out the top dash vents(defroster) by the front windows. Regardless if I set to floor, floor/dash etc it will only blow from the top vent. Any ideas to what I should check for?? Much thanks
  • Thanks all who have responded. Will check out your recommendations.
  • j-d's avatar
    j-d
    Explorer II
    Many Fords seem to have Vacuum Control for Modes (Defrost, Heat, Mix, etc.). A control valve, vacuum servos, and a supply tank with lines. And Electronic control with a variable resistor and motor/gear servo.
    But mice seem to like to chew on both wiring insulation AND vacuum tubing. Apparently both are made with a grain derivative.
    Also, any recent work under or near the dash or engine compartment? I broke a vacuum line in a Ford changing the battery.
  • Ford? You have a vacuum driven system. Look for a vacuum leak....
  • enblethen wrote:
    It could be the linkage to the control or vacuum line to the control
    depending on which you have
    Get ready to hang on to your pocketbook too if you have the new style!
    The NEW heater/ac controls are not like in the old days. They are operated by an assembly part that sits at the very bottom of your dash. Mine wouldn't switch from ac to heat every time.......found out what it all entailed to take dash out and the cost to repair at dealership.....I just left it on AC since I was moving to Florida! :W
  • It could be the linkage to the control or vacuum line to the control depending on which you have.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
