dougrainer
Jun 22, 2016Nomad
Yes, we do get air volume inside but it's not cooled.
Yes, the compressor was running before changing the capacitors but it wasn't running very strong.
Yes, this is a ducted unit.
The lines are icing (not the evaporator).
OK, In 37 years I have never heard of or have seen a Compressor that was not "running very strong". HOW would you determine that??? Especially a novice. Not running strong can mean that you have lost your charge and the compressor is NOT having to pump the full system. Losing a charge will cause certain areas to freeze up, especially if you have a blocked area. That is why you NEED a amp draw of the compressor. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
