Blacklane wrote:
This is really hard to understand.
Which fan are you talking about: the A/C fan or the furnace fan?
What do you mean by "heat and/or A/C in the off position"? Are they both off or is one of them on?
Does it matter which position the fan switch is in: "On" or "Auto"?
If we're talking about the A/C fan turning on, does the compressor also run at the same time, or just the indoor fan?
What brand thermostat are we talking about?
The A/C fan is trying to cycle itself evry few minutes.
The thermostat control has one slider switch that has 3 positions. Heat, Off and A/C. I have this in the off position.
Since the thermostat is Off, the fan switch should be dead I assume. But the cycling occurs no matter which position is chosen.
Not really sure if the compressor is trying to cycle.
Not near the rig at this time so I don't know the brand name of the thermostat.
