ScottG
Jul 12, 2014Nomad
Sluggo54 wrote:
Many digital thermostats have a delay built in, just to eliminate the start against head situation. If you are handy, you should be able to mount a wall thermostat and switch the operation of the a/c off the built-in. There are several threads on how to install a digital thermostat.
The Energy Star rated stat I installed has this feature (wont restart AC for 5 minutes) and it keeps the temps in a tight tolerance. Made both heat and AC work so much nicer.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
