NEOK
Aug 08, 2019Explorer
A/C on 116 volts?
I just pulled into a site and EMS only shows 116 volts. Would you trust it to run 10,500btu AC unit for one night without doing damage go the unit?
Thanks
Thanks
Lynnmor wrote:RoyB wrote:
I have one of these RV120VAC VOLTMETER (AMAZON) installed in one of my AC receptacles to alow me to watch the AC VOLTAGE all the time... This has the GREEN SCALE on it for easy viewing...
That green scale is off quite a bit since anything above 105 volts is acceptable. I suggest buying a digital voltmeter.
solismaris wrote:Low voltage damages the windings on AC motors due to overheating the insulation. The damage is cumulative over time and an AC unit can suddenly fail one day for no obvious reason.
I've run it occasionally with voltage reading as low as 100. Not recommended I know. But no problems yet. Crossing fingers.
Google image
