DelawareRick's avatar
DelawareRick
A/C on generator question
I'm new to the forum and, well, fairly new to the RV world but hope someone can help me understand something. (And I've done a good bit of research via Google, but still haven't found a straight answer that I could understand. That's why I'm posting here.)
First, my rig:
2006 Thor Hurricane 33H
Onan RV Marquis Gold 5500 generator w/about 1000 hours on it
Two 13,500 BTU air conditioners
My questions:
1. Should I be able to run both air conditioners simultaneously using my generator?
2. When I try to run both ACs on generator, the 20 amp breaker on the generator trips. I guess my question is, why not the 30 amp breaker on the generator? (I would think the ACs would/should be connected to the generator via the "bigger" breaker, but maybe I'm just completely backwards in that thinking.)
3. If the generator has nothing drawing power (because its breaker has tripped) would it shut down "on purpose"? Mine did yesterday, about 15 minutes after the AC tripped the breaker. I'm trying to determine if this indicates a problem, a fluke, or is "working as intended".
Thanks in advance for your help.
Rick
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
