DelawareRick's avatar
DelawareRick
A/C on generator question
I'm new to the forum and, well, fairly new to the RV world but hope someone can help me understand something. (And I've done a good bit of research via Google, but still haven't found a straight answer that I could understand. That's why I'm posting here.)
First, my rig:
2006 Thor Hurricane 33H
Onan RV Marquis Gold 5500 generator w/about 1000 hours on it
Two 13,500 BTU air conditioners
My questions:
1. Should I be able to run both air conditioners simultaneously using my generator?
2. When I try to run both ACs on generator, the 20 amp breaker on the generator trips. I guess my question is, why not the 30 amp breaker on the generator? (I would think the ACs would/should be connected to the generator via the "bigger" breaker, but maybe I'm just completely backwards in that thinking.)
3. If the generator has nothing drawing power (because its breaker has tripped) would it shut down "on purpose"? Mine did yesterday, about 15 minutes after the AC tripped the breaker. I'm trying to determine if this indicates a problem, a fluke, or is "working as intended".
Thanks in advance for your help.
Rick
  • Running 2 A/Cs on 30A is marginal unless they are smaller A/Cs. Typically this is where the 5500 shines as it should have one A/C on 30A and the second A/C on the 20A CB. Check to see it there are any other loads on the 20A CB.
    There are a variety of reasons for the tripping CB. Dirt on areas inside and outside, weak CB, hard start capacitor failed or not installed, A/C problems and gen problems.
    Rigs with this gen can be set up to run only one A/C at a time when on 30A shore power, ie they may automatically switch A/Cs but only one will run at a time.
  • OK, On your type set up.
    The 30 amp on the Onan supplies the complete RV EXCEPT the Rear AC
    The Rear AC should be connected to the 20 amp direct. Also may be connected thru a Front rear switch, but still direct to the 20 amp Onan
    That is how 5500 Onans are wired on all Motorhomes.
    I suspect your 30 and 20 amp wires are reversed at the Genset. Not an uncommon problem, especially if any work had been done on the system.
    Start the Genset, turn the 30 amp breaker on the Onan OFF. If you get power to the rest of the RV your breakers are reversed. Doug
  • Twenty Amps is certainly not enough to run two 13.5 k BTU A/C units. It appears your RV is configured to run only one A/C at a time. You should have enough generator power to run both but not through the 20A breaker. Are you certain neither A/C will run with the 20A breaker off?
  • We can run both A/Cs on our generator.
    If we trip breakers, the first thing we check is if the water heater is on electric.
    On 30A shore power, one A/C and the water heater will trip a breaker.
    On generator, two A/Cs and the water heater will trip the breaker.
    We also have a 5500 and two 13,500 a/cs.
    Ours doesn't shut itself off without a load, only a fault. Check the blinking light and refer to the manual.
    Best of luck solving your problem.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 25, 2025
