MickD wrote:
I have a Duo-Therm 600 series air conditioner that runs fine on shore power but when I try to run in off the gen it kills the generator. Should I look at the AC? Like the start capacitor. Or look at the Generator?
Thanks for any help.
It sounds like (obviously) something has changed. I would suspect a weak start capacitor. A/C units are relatively simple. You have a compressor (the largest amp draw) and a fan motor(s). When those motors start, they can draw substantially more current than they do when they are running. The reason it works well on shore power is because there is a lot more available power for the inrush current. You are only limited by the circuit breaker, and circuit breakers are designed to allow a certain percentage of overload for a short period of time. The generator is also limited by a circuit breaker, but it is also limited by the overall horsepower of the engine. When you exceed that horsepower, the engine shuts down (stalls). The more current you pull on the generator, the harder the engine works.
Hopefully that helps.
