Beisek's avatar
Beisek
AC overload
My daughter has a 2004 fifth wheel. We had a 15000 commercial domestic AC put in. Was told it will freeze her out. It's connected to ceiling assembly. Blows cold but can't run on anything higher then low or the breaker trips. It's a 30 amp rv. Anything we can do to get it to handle this unit. We turn everything off and still only can run in low.
  • cekkk wrote:
    I'm pretty sure the word is Dometic.
    I was thinking that too but 'commercial domestic' sounds more like a home unit.
  • 2oldman wrote:
    Beisek wrote:
    We had a 15000 commercial domestic AC put in..
    What exactly is that?
    I'm pretty sure the word is Dometic. It's a brand name of a trailer air conditioner. 15,000 refers to Btus. Most units are 13,500 or 15,000 Btus.
  • To be clear, is it the 30 amp breaker at the post tripping? Or the 30 amp main breaker in the trailer tripping? Or the 20 amp A/C breaker in the trailer tripping?
    I had the 20 amp breaker for my A/C start tripping for no obvious reason. Replaced the breaker with a new 20 amp breaker and no more tripping.
  • On a 30A service you must make sure everything else is on gas. Refer and WH on electric will each draw enough to overload.
  • Something is still running then. Refrigerator, water heater or something else running. Should not be pulling enough to trip. What is tripping. Breaker on pedestal or a breaker on the panel inside. Or something's no not wired right on the unit. Almost no difference in running fan on low or high maybe 1 amp or so.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
