sch911 wrote:
dougrainer wrote:
sch911 wrote:
It still should have a freeze sensor even when it's a non ducted unit. It may be a bulb type rather than a thermistor type however. As previously stated make sure it's still clipped in place...
Freeze sensors have nothing to do with Ducted or Non Ducted. It has to do with the CONTROL system. IF you have a wall Tstat, it will have a freeze sensor system. If you have mechanical ceiling mount knobs, then NO freeze sensor. Doug
That's why I corrected the previous poster who said otherwise....
Be sure to quote the correct post when criticizing...
You were not totally correct. What you stated was true to a degree. What I stated clarified what you did not. Your "It still should have a freeze sensor even when it's a non ducted unit", statement is not correct. You can have manual controls on both Ducted and non ducted systems and they will not have freeze sensors. Doug
