Picinisco's avatar
Picinisco
AC quit blowing cold
Went out for the day leaving the AC running. On our return the AC was blowing warm. I switched it off, went on the roof, took the cover off, cleaned the coil which had just a little bit of dirt on it. When I put everything back together the AC ran fine. Not sure that the minimal amount if dirt was the cause. Any ideas?
  • Picinisco wrote:
    CA Traveler wrote:
    Low voltage? Could cause overheating and compressor shutdown. A voltmeter is your friend.
    Where would I check the voltage
    At any outlet. Best to have a plugin digital voltmeter operating all the time in a easy to see place. Turn off the air conditioner when voltage is down to 105.
  • opnspaces wrote:
    How long were you on the roof? Is it possible the evaporator was frozen up and it thawed while you were cleaning the coils?
    No ice. But the AC was blowing warm air so I feel that if it froze then it thawed when the compressor shut down. Is the system designed to do that and stay shut down until the switch is thrown and then start back up when switched back on.
  • How long were you on the roof? Is it possible the evaporator was frozen up and it thawed while you were cleaning the coils?
  • Low voltage? Could cause overheating and compressor shutdown. A voltmeter is your friend.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 18, 2025
