Terryallan
Sep 22, 2013Explorer II
duggram wrote:
I accidentally set my AC thermostat too low and the unit started. I immediately set the temp higher to turn it off and did this because I didn't notice what temp turned it on. Then I slowly lowered the temp to see what temp turns it on and it wouldn't come on.
After a few minutes I set to temp to a value that I knew would bring the AC on. Nothing. I left it. About 15 minutes later it came on.
That the AC didn't come on immediately when set much lower than room temp, is this a sign of a problem?
Once you turn it off while running. It takes a few minutes to reset itself. Sounds like all is well. It's normal. Scary though huh.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
