- mockybirdExplorerLook for the nests like r luver suggested, mine was same, and I took a wooden ruler to knock it loose without removing cover . Then I shot something like wd40 in there and took the ruler and gave it a hard spin yturn. Removed ruler n turned it back on and it ran like a charm. I also have heard of small squirrel nests too in there
- rvluversnc93ExplorerRemove the cover and I will lay money on the table that you will see a mud-daubers nest on the fan hub. Same thing has happened to me. Once at home the other on arrival in Charleston SC. It's a quick fix if that's what it is. They will build one Especially if it's been sitting unattended and off.
- Dandy_DanExplorerDepending on the AC model, you might check the distribution fan. The Carrier Air V have had problems and no parts available.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
