rrupert
May 18, 2017Explorer
I believe you discovered the problem. You do not want to run the A/C from a circuit and cord that are too light for the job. The A/C was probably struggling for power. It was probably overheating and tripped the breaker. DO NOT run the A/C in this manner, it can do permanent damage to it. Your shore power cord plugged into a 30 amp outlet is the minimum supply you want to use.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
