road-runner
May 18, 2017Explorer III
As already suggested, after the compressor is shut down, you need to wait a few minutes before running it again. Many thermostats have a timer that enforces this, sounds like yours doesn't. As for the power connection being good enough or not, the only way you'll know for sure is to measure the voltage inside the rv when the air conditioner is running. Different people have a different opinion for the lower limit. The air conditioner spec lower limit is 103.5, at the air conditioner, so you have to add at least a couple volts when measuring to allow for losses in the wiring to the air conditioner.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
