LipschitzWrath's avatar
Jul 10, 2017
AC Troubles - Hard Start cap? Something else?
Okay guys, new member, long time lurker.
The missus and I finally bought ourselves a 5er, a 2004 Terry Quantum Ax6. It's huge and we have had it out a couple times. Got a great deal on it and we love it.
Lately it's been getting hot enough that we want to use the AC and that's where the problems began. I am running two brand new Yamaha Ef2000isv2 generators in parallel (kinda), so I feel like I have enough juice. Other relevant details is I'm at 6500 feet elevation and the air condonitioning unit is a Coleman Mach 15k unit. My research indicates it has the factory start capacitor kit installed. Full model number is 8335b6764.
First let's clear up the generator thing. It appears I have a bad parallel cable that yamaha is doing a warranty on. The pins inside the cable broke off and I'm not sure I ever had true parallel capability. Maybe I did but everything I've been told is these generators shouldn't struggle at all to start this ac and I've been successful I think 2 out of 25 times.
Ideas? Could the factory capacitor be bad? Would adding an aftermarket (say spp6) cap help at all or is the factory set up about as good as you can do?
Do I need to get my refrigerant levels checked?
  • Toddupton wrote:
    Wait for the new cable. If it was not working then one of those generators was not going to run a 15k A/C. A new cap would not hurt but with two generators it should not need it. No you can't check your refrigerant and that really will not have anything to do with starting.
    Sure thing. I should have it tomorrow.
  • Wait for the new cable. If it was not working then one of those generators was not going to run a 15k A/C. A new cap would not hurt but with two generators it should not need it. No you can't check your refrigerant and that really will not have anything to do with starting.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
