dwightmccann
Jul 14, 2017Explorer
sch911 wrote:
And you're plugged into 30A shore power? If so check the breaker panel to see if the A/C breaker is ok.
Yes, was plugged into 30 amps when discovered. The circuit breaker for the A/C appears OK and has been reset several times and the 15 amp fuse for the thermostat has been checked (but, of course, it is clearly working ... runs furnace and shows settings in readout.) Have also tried running it with generator, no change.
