TbucketExplorerNov 15, 2015A/C Turns on when I turn on the heaterWhen I turn on my heater the A/C also turn on. Is a gas furnace. So I have to turn the A/C beaker down. If I only use the A/C it work fine. Any ideas. I think my digital thermostat is damaged...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsReplace insulation inside heater column.Water Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???
