Vt Rv wrote:
I'm trying to add an AC outlet in one of my basement compartment. I found a hot line running through the adjoining compartment. When I cut into it I found it's a three wire, black, green & yellow. It goes to the area under the sink. I'm not sure what the green and yellow are or how/if I should splice into it. Is the green ground, yellow hot and black neg?
This shows your lack of knowledge on AC current, so be VERY carefull doing this work yourself. There is NO such thing as positive and negative on 120 ac current. You have
BLACK which is HOT
White which is Neutral
Green/bare copper which is GROUND
The fact you state YELLOW. Are you positive this wire is a 120 line? I have never seen a YELLOW wire in an RV that was used for any 120ac wiring. There may be such a wire, but you need to verify that those wires are indeed 120 volt wires. What makes you think this particular 3 wire is 120 volt? Is this wire ROUND like an extension cord? Is it possible the "yellow" is really white and the age of the RV has discolored that wire from white to pale yellow. Or is this wire REAL yellow? Doug
