golf_bears
Oct 06, 2017Explorer
dougrainer, Paper work doesn't say what model it is but the model number on the warranty is 651816CXX120. The unit is ducted.
CA Traveler, In my discussion with Dometic yesterday they informed me that the heat pump will operate in temp range of 32 to 55 deg. F. I've found that at temps below 37 Deg F that the heat pump is pretty much useless. When temps are going to be below 38 deg. F I stop using the heat pump and turn on the fireplace and the furnace.
