dougrainer
Oct 06, 2017Nomad
There is NO certification separate for AC versus Heat Pump. Anybody that states that is either stupid or they just do not want to work on your unit. IF you are a Dometic Authorized Service center, you should have techs that can work on the units. Dometic will walk any tech thru diagnostics if there is a uncommon problem. Now, NOBODY will allow you to do any type warranty work or do the work yourself. Period. Call Ford and ask the same thing on your Ford if you have one under warranty:B
Which breaker trips? The 20 amp for the HP unit or the main or pole breaker? Doug
The ONLY difference between a HP and an AC is the addition of a reversing valve. Nothing else.
