Alan_Cockrell's avatar
Jun 18, 2019
Accumulator installation
I am planning on much dry camping this fall so I bought a 2 gal accumulator to reduce pump cycles and soften pump start-ups. No installation instructions came with it, not even an online reference. But they are all basically alike and I did enough research to figure it out....mostly. It won't fit in the space where my pump is, in the bathroom, but it will fit nicely under the kitchen cabinet. So, I have 3 questions. 1. Will locating it so far from the pump reduce its effectiveness? 2. The under-sink plumbing is convoluted and hard to figure out. I did however discover that the water heater input line, when disconnected, spurts a lot of water when I turn on the pump. Seems that's a good tie-in point. Correct or not? 3. Should I make life simple and run single line to the accumulator or run two lines that route water through it?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
