wa8yxm
Jan 26, 2019Explorer III
Though the logic is not... IN my not very humble opinion valid. WHY did someone say that electric was better if you boondock a lot and propane if parked on a nice level pat at a campground.
Because he does not understand how to level his trailer.
You see Propane needs to be close to level (Generally within 3 Degrees. Does anyone have any idea as to how much OFF LEVEL 3 degrees is.. side to side over 4 1/2 inches. that's 3 slabs of 2X tire width folks)
But electric fridges are good if 3-or even 14 degrees off level (Danger of rollover off level).
Clearly you are not going to be leaving your RV that off level if you plan to sleep in it. SIde to side (I worked it out several times and it's over 3 slabs of 2x lumber no Bouncing down the road by the way it does not matter so much...
I went with Propane.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
