RVhiker
Apr 08, 2015Explorer
I'm wondering about the safe voltage to supply to the Jetpack. I understand that USB voltage is 5 volts DC, but I wonder if the presence of the Jetpack battery in the circuit lowers that voltage some (the battery is marked 3.8 volts DC). So, if I use a USB power supply - at 5 volts nominal - and do not have a the Jetpack's battery installed - would I supply a harmful voltage to the Jetpack?
My desire to run the Jetpack without an installed battery is that my original Jetpack battery swelled up. I have a replacement battery on order, but I noticed that the OEM batteries that I prefer are not in ready supply (not even from Verizon). So since I usually have the Jetpack connected to the RV DC system, I really don't need a Jetpack with a battery if I can connect it directly to the RV system; and thus eliminate any issue of over-charging the lithium battery.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
