pianotuna
Jun 30, 2017Nomad III
Hi,
Mine is ducted with a wall thermostat. I wanted to be able to run the heat strip and the furnace at the same time, so I added an extra thermostat for the propane furnace. It works well.
DiskDoctr wrote:
3. Has anyone used an extra wall switch near the thermostat (I changed to digital non-programmable heat/cool thermostat) to switch between electric heat strip and propane furnace?
3a. If so, how do I get the Brisk Air system to fire up the heat strip and fan (currently wired for HIGH speed only)? I can work out a "special" DIY control if necessary, but I'd rather just duplicate someone else's simple solution- if there is one ;) (no thermostat).
I want to be sure this "new setup" works with the thermostat and retains the designed protections and such to not overheat and melt down the roof :E
Someone please tell me there is a good mod writeup for this!
Thanks! :)
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
