Vintage465
Jul 02, 2016Nomad
So, the set up you did here is 11" water column right? I need to run a high pressure line from the tanks to my gas grill. My trailer came with the high pressure tap already installed before the regulator and a quick connect with hose. I am thinking of leaving that in place running 3/8" stainless with stainless compression fittings (2000psig rating)to the grill and having a quick connect at each end. When I want to use the grill, I can "hot up" the line at the tank quick connect and hook up a quick connect hose at the grill. The only drag would be having to purge the line prior to lighting up.
Thoughts?
Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
