BB_TX
May 11, 2021Nomad
12 vdc times 10 amps equals 120 watts.
120 vac times 1 amp equals 120 watts.
So in the perfect world you could run a 120 watt inverter.
BUT. There are power losses involved in the inverter meaning you would only be able to run something less than 120 watts out of the inverter without popping the fuse. So you can count on maybe getting 3/4 amp or so of 120 vac out of the inverter.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
