yobie
May 03, 2013Explorer
MEXICOWANDERER wrote:
Wire it the same way as the older RV's where you need to unplug from shore power and replug into the genset. But you are going to be attempting to power a rig with about 1/3rd the power that it was designed for. I hope you realize it, going in. Few people have automatic awareness of how much power their rig is sucking unless they have a power meter where it can be monitored with ease.
The rewards of loading a generator to "almost where it stalls" are few. Usually the genset will let you know it does not like your duty roster by failing,
That is what I want to do just wire it up as the old ones are. I understand the difference between 50 and 30 amp as I have used both many times as well as my generator.
That is where my question comes in. Wasnt sure what to do wit the extra hot wire.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
