westend
Aug 08, 2016Explorer
It appears that the left side of that load center has a removable face panel. I see a thumb indent in the plastic panel, a sign that it is pressed to remove it.
The process would be to remove the left side plastic panel, remove the plastic knockout cover above a vacant breaker space, install the new circuit breaker, attach circuit wiring to breaker, neutral bus, and ground connection. Test circuit. Replace plastic cover on left side of load center.
Good luck.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
