kbehrent's avatar
kbehrent
Adding solar with existing inverter/charger
I have a factory installed Xantrex RV2012 2000w inverter/charging installed in my motorhome. I am looking to add solar panels to help reduce generator runtime when we are dry camping, which is most of the time. I'm looking to add upwards to 400W of solar capacity.
I have 4 Interstate batteries (GC2-XHD-UTL 6V, CAP-20: 232AH, ReserveCapacity25: 474AH) connected in series/parallel to provide 12VDC and @ 474AH (If I calculated it right)
It seems all the articles I've read assume you have nothing but an existing battery and no inverter capability. Since I have both an existing inverter/charger capability in my Xantrex, How do I integrate solar charging with my Xantrex to help charge/maintain the batteries? Note, I also have auto generator start capability to charge my batts when batteries reach a specific % of SOC, which is currently set to 50% SOC.
If the generator should start and cause my Xantrex to start charging the batts, do I need to disengage the solar panels? Is this done manually or will a solar control panel of some type auto sense this and disconnect the solar panels?
Thanks
  • kbehrent wrote:
    Any recommendations for 100W panels and controller? Are they usually paired or do you buy the best panel for the money and than buy the controller separately?
    You'll find 120-135 panels more popular. No, yes, then, yes.
  • Any recommendations for 100W panels and controller? Are they usually paired or do you buy the best panel for the money and than buy the controller separately?
  • Remote panels are a great option, don't bother with adjustable mounts on the roof for optimization. Climbing up and down the roof gets old real quick.
    Ron W
  • kbehrent wrote:
    pianotuna wrote:
    232 x 2 = 464 amp-hours.
    Minimum solar panel size no less than 279 watts
    If you plan to use the inverter much then the sky is the limit on solar wattage.
    I'm looking at @ 400W of solar. I really don't want more than 4 panels so I'm limited to that. I don't want to attach them to the roof, so I'll build/buy a portable stand. I realize I might not get the best optimization this way, put I like the portability of it in case I want to use the panels for something else if not being used for the motorhome.
    You might actually get better optimization this way. You can angle them towards the sun, adjust the throughout the day, park in the shade and put the panels in the sun, etc.
  • 232 x 2 = 464 amp-hours.
  • kbehrent wrote:
    Is there a connection between the solar controller and my Xantrex?
    The only connection will be that they are both connected to the battery.
    Xantrex will just operate as if the battery is always fully charged because it will be. Or if sun is weak or your usage is strong the Xantrex will just operate as what you think as normal.
  • There is no special consideration to be taken when integrating a solar charging system in parallel with an existing inverter/charger other than getting wiring nuances and circuit protection correct. Possibly, the reason you don't see mention of it with solar installation methods is that it is mostly a non-issue.
    BTW-your 4 x Interstate GC2's have a combined capacity of 464 AH.
  • Shadow Catcher wrote:
    Panels to solar controller to battery bank, the other things play well together with the controller.
  • Panels to solar controller to battery bank, the other things play well together with the controller.
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 17, 2025
