FWC
Mar 26, 2021Explorer
VHB tape works well. Even if you just put it around the edge, there is a ton of surface area to work with, so it is relatively easy to get a good bond.
The flexible panels are less durable than the rigid ones, but there are still good reasons to use them. If the panels you are looking at have grommets in the them you can also consider using glue on studs for the mounting with some Sika:
https://duckworks.com/glue-on-studs/
http://www.weldmountsystems.com/products-fasteners-stainless-studs.php
That way it is dead easy to replace the panel. Even if you just VHB around the edge of the panel, it will be a chore to remove them.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
