joebedford's avatar
joebedford
Nomad II
Aug 11, 2019
Adjust brakes with drop axle??
I've adjusted brakes without problems on my trailers with straight axles. My little trailer has drop axles I guess to keep it close to the ground. The piece that makes the drop almost covers the brake adjuster slot. I don't see how to get at the cog with my bent screwdriver. Any suggestions?
  • You probably need to adjust once a year at most,......adjust them when the drums are off for inspection,......just tighten till the drum just slides on.
  • They do make a brake spoon that will work, I think I have 4 from when I worked for a living.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
