theoldwizard1
Jun 04, 2017Explorer II
2oldman wrote:
piano... can you explain to me the difference between a charger that claims constant amp vs contant voltage?
Using the "water in a hose" analogy ...
Voltage is like water pressure. You can have pressure even when the nozzle is turned off.
Current (amps) is like water "flow" (gallons per minute).
If you have something sucking (not just a spray nozzle) on the hose and you want a constant number of gallons/minute it will take more pressure (this is a power supply that is in constant current mode with no voltage limit).
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
