2oldman
Jun 04, 2017Explorer II
DrewE wrote:Ok. Let's say my battery is sitting at 52 volts (yes I have a 48v system), and a full charge is 58.4. I have a constant amperage charger that supplies 20 amps. What is the voltage delta as it rises? IOW, how many volts over the battery voltage does it need to maintain to "pump" in those amps?
To maintain, say, a 7.5A charge current, you'd set the constant current knobs for 7.5A and the voltage knobs for the maximum voltage and let the power supply adjust the voltage for you.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
