Naio's avatar
Naio
Explorer II
Jun 04, 2017
Adjustable amperage for restoring AGMs?
I was reading in the Lifeline manual about this. They say to charge at constant current of 5 percent rated 20-hr capacity until 15.6v, then continue 4 more hours. It may reach 18v, be sure your system can do that.
So how does one get this constant amperage? With one of these?
If it's the right device, I thought it also might be useful for topping off my Fiamms. They prefer 14.1-14.4v, but I bought a PD which puts out 13.6, because I need something plug and forget for when I am tired and befuddled.
So, when I wake up in the morning, I could top them with this puppy, yes? And restore them at constant amperage if they get sad?
The Fiamms are 132aH, and want 6.6 amps for restoration. 5 amp max adjustable amp supplies are cheaper...is 5a close enough? And just keep turning up the voltage as needed?
Would I know more voltage is needed because I set amps at 5 or 6.6, and volts at x, then watched the readout and saw amps drop? Then I would turn volt dial until amps get up to spec again?
I am just making sure I've got all this right bec I am not an EE pro like some of youse guys! Plus I thought if it's the right PS, some of you might want one.
  • piano... can you explain to me the difference between a charger that claims constant amp vs contant voltage?
  • Hi Naio,
    Time to "dance on the needles"? Constant current is what you desire. The one you linked to can do 10 amps.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 15, 2025
