landyacht318
Mar 30, 2017Explorer
MEXICOWANDERER wrote:
These alternators have a 3.0 ohm rotor coil. At 14.5 volts = 4.83 amperes or 70 watts. You can come to your own conclusion about component life-span.
Is the only difference between a 50 watt and hundred watt 10 ohm resistor the Extra Surface area in which to dissipate the heat?
If so hopefully I mitigated that with the added heatsink on the 50 watt resistor.
Can't remember for sure, but believe I have seen 6.8 amps of field current on my field wire from transpo540HD when the battery was super depleted with my DC clamp meter.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
