Old-Biscuit
May 11, 2018Explorer III
Homeless by Choice wrote:
DrewE
105F Warn is much better than cold. I want my LP for furnace and fridge. Water and dump sites are readily available compared to LP refill stations.
Old-Biscuit
Sorry, I should have initially included that info.
It is an Atwood, 6 gallon, LP only, model G6A-8E water heater.
Edit: It has "E.C.O." on a rubber cover where the four wire go thru.
LeRoy
The rubber cover is actually a foam insulating pad so T-stat & ECO are not exposed to outside air and only to tank wall temp
T-stat can be replaced with the Optional Adjustable T-stat (110*F - 150*F)
It comes with a bracket to hold the larger size t-stat.
Small screw adjustment on face to set temp t-stat opens at (the lower the set temp the lower the temp has to go before t-stat closes to reheat)
BROWN Wires connect to it....short pigtails are included.
Atwood Adjustable----93105
Atwood DOES have an optional Fixed 130*F T-stat -----91470
(IS a 130*F fixed but SOME packages/advertisements list it as `120*F)
ECO (Energy Cut Off...Hi Temp T-stat) remains in place. It is set to Open at 180*F and shut down ALL heating.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
