BFL13
Nov 01, 2015Explorer II
Yes Randy's adjustable models are pretty much the same as what I have.
I do like my adjustable PowerMax units. I think you would be pleased with the adjustable 60 for your T-105s.
They are "manual" so if used as an RV converter, you need to be able to get at it and see what you are doing.
Yes it can do it all. You can do the Trojan 14.8, you can equalize at 15.5, you can Float at anything for the temperature at the time, you can adjust your other voltages to suit the temperature too. eg, 14.8 at 77F is 15.1ish at 32F. Except equalizing in the cold! It only dials up to 15.5 :)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
