Chris_Bryant
May 04, 2016Explorer II
Gjac wrote:westend wrote:My understanding is that 50 amps goes to the house for the 2 A/C's, MW etc. but only 8 amps are available to the charge the battery. Am I not understanding this correctly?Chris Bryant wrote:westend wrote:
The table in the owner's manual lists an amperage output of 8 amps. If that is all you can push to a discharged battery, it will be a long time to fully charge a battery. For float charging or maintaining, it may work well..
You are looking at AC input amps. Output is 50 amps.
You're absolutely correct. I need a brush up course on reading comprehension. Sorry about the misinformation.
All 50 amps of DC output are available for charging, but the voltage isn't high enough to do a great job of charging- I see they spec it at 14.1 volts at no load, but under charging load voltage is lower.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
