Old-Biscuit
May 22, 2021Explorer III
A1B00902 wrote:
Used to in the old days, backup quickly and hit the brake hard,
Trailer self adjusting brakes do so when going/braking forward
As for Dexter Never Adjust......YES they can be manually adjusted
The Dexter Nev-R-Adjust electric trailer brakes can be manually adjusted. There are a couple teeth of the adjustment wheel that are exposed just under the lever
Attached is a photo showing the teeth. You will likely need a tool with a fine edge such as a flat head screw driver for the adjustment wheel on these brakes. A brake adjustment tool may be too thick.
