MrWizard
Jun 01, 2015Moderator
generator, put an hr meter on it ( they are cheap )
change oil every 100 hrs
clean air filter at each oil change
carbs only go gum up when allowed to set with fuel then dry out
use it every day or every week and there will be NO carb problems
generators work day or nigh sunny or cloudy, mount it on a hitch carrier on the back, lock it up, put a cover on it when not in use
get a good battery charger, you can charge anything anytime
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
