Naio
Jun 02, 2015Explorer II
pianotuna wrote:
Another issue is the effect temperature change causes on charging voltage. It needs to be addressed by having a sensor on the negative post of the battery.
Ok, thanks. Does the sensor connect to the solar controller? If so, it too needs to be detachable on the 24v system.
smkettner wrote:
If the 24v motor is small you may switch all batteries to 12v and power the motor direct through the 12/24 converter.
It's 2hp and ocassionally blows a 100amp breaker. And its use is primarily away from the rig.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
