dougrainer
Aug 24, 2015Nomad
EZ Lube and Bearing Buddies are designed to allow the owner to pack grease into the outer void of the wheel hub to prevent the Lake Water from getting into the bearing hub assbly. They are NOT to be used to "clean/PACK" the actual bearings. When you PACK a bearing you are forcing the OLD grease out and pushing in new grease. That cannot happen with an EZ lube or Bearing Buddy. If you try, it will bulge out/blow out the axle seals. Then you will have one heck of a greasy mess all over and on the brake shoes. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
